Have you ever wondered that a cold intake system is one of the most essential elements of any truck? By means of it, you have all the chances to raise the power and torque of your truck and get a much more efficient operation of your motor, especially in hot weather. But you may still have a few questions regarding the cold intake system. That’s why today I’m going to answer the most often asked questions about the process and purpose of this system.
What Does a Cold Air Intake Do for a Car?
The cold intake system is a modern and very popular type of engine tuning, which is able to qualitatively lower the degree of heating of the air entering the motor, thereby upgrading the efficiency of filling the cylinders with it. In other words, the air with which the motor operates should be as cold as possible, so that the greatest recoil occurs when the accelerator pedal is pressed. This is the function the air intake system is created to perform.
In any engine tuning and simply its maintenance, the fuel-air mixture is one of the head parts, on which the power characteristics depend. However, OEM air filters are equipped with a filter component made of incredibly dense material, and its design can’t provide enough flow of this mixture into the cylinders. So, the cold air intake is a zero-resistance filter with microscopic openings that allow a much larger volume to flow through.
Does a Cold Air Intake Keep Engine Cool?
There is only one answer to this question and that is yes! As we all are aware, the cold intake system is a device that delivers cold air into the internal combustion motor in order to raise its power.
The factory intake system has plenty of airflow resistance. The reason for this is the paper filter and the manufacturer’s desire to lower noise. The factory intake takes the air from the hot motor compartment, this greatly lowers the power of the motor.
Cold intake companies make kits in a variety of shapes and sizes. Cold intakes are affordable for special truck brands and, moreover, universal. With a cold injection system, more oxygen goes into the motor, which significantly upgrades the engine’s power output.
What Are the Benefits of a Cold Air Intake?
Well, one way to add a few powers to a truck is to set up zero resistance filters. But like any system, a cold air intake system has its advantages and imperfections.
The benefits of a cold intake system are:
- Improved motor power and torque;
- quicker start-up of the turbocharger;
- increases accelerator pedal responsiveness;
- significant reduction of fuel consumption;
- less chance of detonation;
- engine runs smoothly and gently;
How Does Cold Air Intake Affect Gas Mileage?
My answer, of course, is yes. One of the proses of a cold intake is the greater gas mileage. We already know that internal combustion motors get their energy by burning fuel, and that requires enough oxygen being pumped by your truck’s motor. But if we speak about the shortage of oxygen, more fuel is consumed. Cold air intakes are created so that you receive the proper amount of air to the fuel, which raises horsepower and upgrades fuel savings. The cold air intake kit lets air flow freely through the vehicle’s motor.
How Does Air Intake Affect Performance?
In fact, while statements about actual power and even upgraded fuel efficiency can vary, cold air intakes will actually help upgrade your truck’s efficiency. And it’s true, a cold air intake system will definitely enhance your truck’s performance and efficiency.
Does A Cold Air Intake Hurt Your Engine?
Nowadays cold air intake kits are surely safe to utilize on your vehicle, but there are things that can arise which can be bad for your motor. This rolling effect can throw off the mass air meter, delivering an inaccurate reading back to the motor, which throws off the proper air-to-fuel mixture. This can cause your motor to stall.
But, that raise in airflow and lower ignition temperature could give upgraded efficiency, and if you drive rougher, then you will nullify the proses. If you keep your previous driving style, then the motor will work much better.
How Much Horsepower Does an Air Intake Add?
In reality, there is no exact answer to this question. Because with a new air intake, you can get an increase of 5 to 15 horsepower, although that number may be higher or lower depending on your truck brand and motor size.
This change can be attributed to several factors, including the location of the upgraded air intake. Normally, cold air intakes move the system of the stock location so that it inhales denser, colder air near the fender, rather than lighter, hotter air above the motor, which promotes better fuel combustion. The ramp air intakes use a big intake duct at the front of the motor compartment, which carries air into the system before it is heated by the motor.
In addition, the air filters in the upgraded air intakes are bigger, which supports increased airflow. The materials used to raise the degree of filtration, which gives great advantages in cotton over the paper and in oil over-dry air.
What Is the Purpose of Air Intake Hose?
As you know, the car requires clean air, filtered from dust and other parts of the outside environment (insects, abrasive dirt, etc.), to produce the fuel-air mixture. The tightness of the contact between the parts will be broken and the compression will decline, and the motor output will drop. Thereby, the air is fed through a special filter where it is cleaned. The air supply from the filter to the motor is through a hose.
In vehicles with the filter positioned at the radiator frame, air intake hoses are additionally set up in the corner between the fender and the front panel of the motor compartment. Even more important that fact, that their air intake ends are brought out in front of the radiator, away and higher from the wheels, the enclosed space, if a filter is installed in it. This provides not only a great supply of cool air but certainly protects the filter from road dirt and dust:
- Air intake is created in the structurally maximum safe area of underhood space in terms of the probability of dirt and dust ingress.
- If there will be something in the incoming air, the small debris (dust) partially, and most of the large debris will settle or be trapped in the intake hose and then fall out of there by itself.
How to Select Cold Air Intake?
In order to choose the right and most durable cold intake system you should consider the following 5 steps:
- Firstly, you should be aware that the product you are buying and setting up is required for your particular truck.
- You need to select a material that is created of heat resistant materials.
- Style. There are on the whole two of them: the short ram system and the truly cold air intake system.
- Suction tube flow. If you own straight hoses, airflow is way more efficient compared to really curved hoses.
- water resistance. It’s so essential to buy a cold air intake with lots of protection against water or wet weather.
Do Cold Air Intake Kits Really Work?
Theoretically, cold air and receiving more air is great, but it doesn’t matter if it’s not put into use. While the actual raise in power and fuel savings may vary from one car to another, one thing is for sure it can certainly upgrade your car’s efficiency. As some creators say, cold intake can add anywhere from 5 to 20 horsepower. Still, a cold intake system certainly lets you have more fun driving your car.
That’s It!
I hope I have answered all your questions related to the cold intake system and how it works. In fact, this product has many more advantages than disadvantages, so I highly recommend you to buy it soon. Now you already have a lot of information about this system and it will be much easier for you to choose the right one for your car. I hope you enjoyed this tutorial and you will also write some comments under the article about your experiences and thoughts on this.
