Often when you think about investing in the quality cold air intake, the first thing that comes to mind is improved airflow provided by the item. However, the list of benefits that a well-chosen cold air intake can provide is far greater than that. The fact is that Best Cold Air Intake for BMW can improve the overall power of your ride. Apart from that, the item will add up to the fuel economy as well as horsepower and torque. Depending upon your BMW model, you can pick the most fitting option based on the provided research.
Best BMW E36 Cold Air Intake (3 Series) (Updated December, 2020)
Best BMW E36 Cold Air Intake Review
1. aFe Power Magnum BMW E46 Cold Air Intake Kit
When your engine starts to suffocate, there is barely anything you can do about it but consider changing the stock air intake. If we take aFe Power magnum, it is safe to say that the item is designed to improve the airflow by 80%. It does not take a genius to figure out that it is a significant improvement. In case you belong to the category of drivers who like to make the most of the vehicle, then you will mark the advantage.
Apart from that, the cold air intake from the brand is designed to introduce up to 20 additional horsepower and significantly improved torque. The filter that the item comes with is not only durable, it is washable and oil-free. Besides, the intake system is equipped with a quality heat shield that keeps the hot air out of the engine so that the performance does not worsen in no case.
When you are looking for the best quality, you should check the most trusted vendor out. However, you should be willing to pay a little extra for the flawless performance. If that is okay with you, then the aFe system is the one designed for you.
2. Injen SP1105P Air Intake System
If you are looking for a balanced factory air and fuel ration spiced by a flawless air intake system performance, then Injen has your back. When compared to a variety of other brands, Injen seeks out the golden middle so that you do not take the engine to the heights it can’t conquer.
The system is perfectly designed so that it is lightweight and corrosion-resistant. Apart from that, the item is aimed at providing absolute maximum horsepower level fit for the vehicle. Unlike aFe’s filter, the one from Injen is well-oiled and designed to provide quality airflow with the ability to filter any obstruction out.
To put it simply, the brand has done its best to provide consistent horsepower as well as torque gain through well-calculated aggression provided by pressurized mass air.
It is true that Injen’s intake system is not the most powerful on the market, but it is well-balanced, and for the majority of drivers, that would be more than enough.
3. Rtunes Racing Cold Air Intake Kit
At times when you wish to improve the engine performance as well as increase the horsepower and throttle response, you can’t afford to get the highest quality cold air intake system. There is nothing to worry about since there is always an excellent budget-friendly option to consider. Rtunes Racing intake system may not be the best in the industry but is undoubtedly deserves attention.
The kit is designed to assist the engine in getting more air thus, the horsepower, as well as throttle response inevitable, gets better. The system kit comes with all the necessary items required for a successful installation. Also, the system is equipped with a reusable filter, which will extend the lifetime of the item.
Those of you who are looking for the quality cold air intake system substitution without blowing the hole in their pockets should definitely pay attention to what Rtunes Racing has to offer.
Best BMW E46 Cold Air Intake (3 Series) (Updated December, 2020)
Best BMW E46 Cold Air Intake (3 Series) Review
1. K&N Cold Air Intake Kit for BMW e46
If there is a system that has been designed directly to impact vehicle performance, it is safe to say that K&N totally belongs to the category. The fact is that the system is not only performance-oriented, it is also a lot more durable than all the predecessors. Unlike the variety of systems, the one from K&N also comes in a range of finishes and coating so that you can pick the one that suits you most.
The filter that the system is equipped with deserves particular attention since it is truly a masterpiece. The thing is that the filter is oriented at the ultimate air supply while keeping all possible contaminants out. All that adds up to the power increase as well as the torque. Another peculiarity about the intake system is the fact that it is proved to come in useful when it comes to towing. The truth is that when you are towing up, the acceleration affects the throttle response in a positive way.
Those of you who often find themselves dealing with towing should pay special attention to the K&N intake system. It is designed to improve the experience along the rest of more casual advantages.
2. aFe Power Magnum FORCE 51-20442 for BMW e46
It is true that aFe belongs to the range of the most reliable Jeep aftermarket brands, and there is a number of reasons for that. If we take the cold intake system that the vendor provides, one of the most peculiar things about it would be the improved 6 max horsepower production. That is a significant performance upgrade that any driver will certainly appreciate.
Apart from that, the system is equipped with a durable heat shield and an oil-free filter, which is washable too. The particulate coupling incorporated into the system ensures a safe air transition for improved performance. While the set seems to be quite powerful and complex, it is super easy to install even if it is your first time dealing with the cold air intake installation.
At times you wish there was a cold air intake system that is simple to deal with on one's own bust potent enough to affect the performance in a good way. That is when aFe systems come in.
Best BMW E90, E91, E92, E93 Cold Air Intake (3 Series) (Updated December, 2020)
Best BMW E90, E91, E92, E93 Cold Air Intake (3 Series) Review
1. aFe Power Magnum FORCE 54-11472 Air Intake
One of the main intake system elements that provide the airflow into the engine is undoubtedly the filter. aFe ensured that the filter their system is equipped with is huge enough to provide enough air for flawless vehicle performance. The filter itself is 5-layered, well-oiled, and washable, which extends its longevity.
The heat shield which the main purpose is to keep the heat out of the engine is made as one-piece. As to the stock intake tract, it is professionally substituted by a molded plastic tube, which is also heat-insulating.
Undouble quality comes for a price. However, the range of benefits that aFe intake system offers is certainly worth the investment.
2. BMS Dual Cone Performance Intake System
In case you are mostly interested in a budget-0friendly option to substitute your factory airbox, then I may have something in store for you. The thing is that BMS Dual Cone Performance Intake is probably among the most affordable ones on the market, but the price does not affect its effectiveness. The item is designed to provide flawless engine operation due to increased air supply. Apart from that, the way the item sounds when on is genuinely ear-pleasing.
The package comes full set so that no additional hardware is to be used. Apart from that, the system is designed in such a way that it is super easy to install without any need for cutting or drilling. Also, the filters come in a range of different colors to choose from.
The best budget-friendly intake piece to be found on the market so far.
3. aFe Power Magnum FORCE 54-81012-B BMW E90 Air Intake
Those of you who are considering doubling the factory intake should pay particular attention to another aFe intake system. The system is designed in such a way that it introduces about 12 horsepower into the performance. It is well-equipped with a popular washable air-filter of conic shape. There is an auxiliary inlet duct aimed at improved airflow spiced up with a vacuum-shaped cover so that the system is easy to access when needed.
Heat-insulating tube that the system features is designed to direct the airflow so that the performance improves. Lastly, but not less importantly, the system is well-balanced and properly-manufactured so that it will introduce that elegant vibe along with the simplified installation.
Sometimes it helps when you realize that the cold air intake has been produced for your 3 series particularly, and aFe has accented the fact heavily throughout the design of the system.
To sum all up, it is safe to say that the cold air intake market is more than vast and versatile these days. However, when you are considering a significant investment into the system, it is vital that you find the best piece to experiment with. I have tried my best to list all the most reviewed systems for BMW 3 series. The rest depends upon you. When it is a major horsepower boost you seek or budget airflow improvement – you will find either in the review.
