Let’s get one thing straight right from the beginning: an aftermarket air intake won’t turn your Silverado into a sports car. Nor will it give you twice the HP or torque of the stock gear. In many ways, it’s more of an accessory rather than a performance-oriented upgrade. Its #1 goal is to keep the engine safe from overheating by maximizing the airflow. That will also boost the efficiency of the powertrain, but only by 5-8% (10% tops).
And now that we’ve got that out of the way, join me, and let’s look for the best cold air intake for Chevy Silverado 1500. The following list includes four top-of-the-line intake kits that offer the best balance of price, quality, and ease of use. Check the comparison table first, and then move on to the reviews!
Best Cold Air Intake for Chevy Silverado 1500 (Updated December, 2020)
Best Chevy Silverado 1500 Cold Air Intake Review
1. K&N Cold Air Intake for Chevy Silverado 1500
As a leader in the market of air intake systems, K&N is always expected to deliver the best performance. And you will get exactly that with this kit. It was specifically designed to maximize the airflow in a V8 engine and will be a perfect fit for this vehicle. With an airflow boost of up to 50%, it’s one of the most capable solutions for a regular driver. You’ll get a decent increase in HP, torque, and towing as well.
Add a premium-grade filter that keeps debris at bay and protects the engine from contaminants, and you’ll get a bargain. As always, K&N backs its product with a 10-year or 10-million-mile guarantee – that speaks volumes about this cold air intake’s durability. Sadly, the plastic fittings that come with the package won’t do you much good. They’re pretty cheap, and I recommend ordering a set of brass fittings: they’ll do a much better job.
Durable, long-lasting, and incredibly effective for the Silverado 1500 V8 – that’s the K&N air intake in short for you. It also safeguards the engine compartment from debris and features a generous manufacturer’s guarantee. Just don’t forget to throw away the low-quality fittings and get something more reliable from a local store/online.
2. Volant PowerCore Cool Air Intake
Easy installation and enhanced compatibility are this product’s biggest selling points. For the average driver, it will take less than an hour to finish the installation, which is quite impressive. And yes, this air intake is compatible with a long list of pickup trucks, not just the Chevy Silverado. Another standout feature is the high-quality air ducts. They were specifically engineered to achieve maximum airflow.
Now, I have to also mention that although installation is straightforward, there are still some “hidden dangers” that need to be addressed. Depending on your Silverado’s model year, there may be some cutting involved. Mostly, this refers to the older editions. Furthermore, the air sensor is a bit too big and it can be tricky to align it with the adaptor.
Despite the minor fitment issues/challenges, this cold air intake system will be a safe bet for a Silverado owner. It takes very little time to install, features a top-of-the-line air filter and ducts, and will instantly improve the engine’s performance both on and off the road.
3. SUPERFASTRACING Cold Air Intake System
This is the most affordable product on today’s list, folks. So, if you’re on a tight budget but still want an aftermarket set that will do justice for your truck’s engine, you may want to keep this one in mind. Compared to most rivals, the price-tag is, indeed, significantly lower. At the same time, it’s just as good in almost every regard. Now, I say almost, because the material quality leaves a lot to be desired.
It’s not horrible, of course, and the kit is quite sturdy and reliable. Still, the coating and the actual materials are average at best. On the bright side, the air intake is available in four colors, including a stylish black+red combo. Plus, it comes packed in a protective, impact-resistant box and includes detailed instructions. For most folks, that is more than enough to put it on their must-have lists.
Looking for a low-priced air intake with a decent output? Superfastracing might have just the right offer for you. True, the material and build quality aren’t its strongest suits, but, overall, this is a solid air kit. It will boost the airflow, increase the “horses” and towing capabilities, and take performance to the next level.
4. aFe Cold Air Intake for Chevy Silverado 1500
Unlike the previous option, the aFe air intake is quite an expensive treat. It is available both with a three-layer (dry) and a five-layer (oiled) filter. These filters are made of washable cotton gauze media and greatly improve the airflow in a V8 engine. With this kit, you’ll also get a urethane plug that can be used for sealing. The price tag is steep, however, but you’ll get incredible construction and material quality for that.
So, ultimately, it’s up to you (the buyer) to decide whether all those pros outweigh that one con or not. Here’s my advice: if you’re in the market for durable, premium-grade air intake to maximize Silverado 1500’s airflow/engine performance, this will be a good investment. But if you’re going for something simpler and less expensive, look elsewhere.
Here, we have one of the most capable and reliable aftermarket cold air intake kits out there. It boasts impeccable build quality, features a top-notch filter, and a long list of extras. Unfortunately, the price isn’t at all user-friendly and will be a big turn-off if you’re on a budget.
No matter how much you love your Silverado truck and how much you take care of the powertrain, it does have certain limitations. And to make sure it’s always in a good “shape” and performing at its full potential, you should consider some aftermarket upgrades. Today, we talked about the importance of a cold air intake and checked out four outstanding products from world-known brands.
With Superfastracing, you’ll get a low-budget air kit in a secured package. aFe, in turn, boasts top-of-the-line material quality but will cost you more than the industry average. The other two options are similar to each other but also have their pros and cons. So, which one is the best pick in your opinion? Share in the comments!
