Historically, air kits used to be the “weapon of choice” for professional rally drivers. Engine failure due to overheating is a fairly common thing, especially in off-roading in the deserts. In a pro-grade air intake system, the filter is located outside of the engine bay. That ensures a more efficient cold airflow. And these days, thanks to an increase in demand, these systems are also largely available to regular drivers.
So, if you’re a big fan of conquering the wilderness behind the wheel of your trusty pickup truck, you might consider buying one. The best cold air intake for Dodge Dakota will not only keep that powerful engine cool but also maximize performance. You’ll get more HP, torque, and maybe even an improved mileage. So, let’s check out what the market has to offer!
Best Cold Air Intake for Dodge Dakota (Updated December, 2020)
Best Cold Air Intake for Dodge Dakota Review
1. K&N Dodge Dakota 4.7 Cold Air Intake
For your Dakota to be the star of the show every time the hood is popped off, K&N’s air kit might a good purchase. It does, indeed, look great thanks to the trademark design. On top of that, the kit significantly improves the engine’s sounds, making it aggressive enough to scare the birds in the forest. It’s also worth mentioning that this air intake system features high-quality cotton fibers.
They were specifically designed to protect against contaminants. Precision engineered and built to last, K&N’s product is one of those can’t-go-wrong-with picks. It will cost you a pretty penny, though, but the price is well justified by all the pros that we just discussed. If you’ve got some basic tools and a proper set of hands, you’ll handle installation on your own in less than two hours.
Are you ready to invest in a premium-grade, long-lasting aftermarket cold air kit? If the answer is yes, then this may be a reasonable choice. It fits the Dakota perfectly and both looks and sounds good. The price-tag isn’t particularly user-oriented, of course, despite the market-leading quality.
2. Cold Air Intake Systems for Dodge Dakota by Dynasty Store
DNA’s air intake kit is bright and eye-catching. It is not as fancy as the one by K&N, but it does, most certainly, bring attention to itself. As for the technical side of things, the AIP intake system has already proven in numerous tests that it boosts air filtration by quite a lot. The filter is very easy to wash. You can use water and some soap for that – no need for specific formulas or anything else.
The build quality is decent, even though the whole thing is quite lightweight. And what about the installation, you might ask? Well, while this air kit was designed for the Dakota, it’s not the easiest fit for the Dodge 4.7-lit engine. You’ll have to extend the harness – it’s a bit too short. Plus, the air hose’s diameter doesn’t match that of the engine. Other than that, it won’t be very hard to mount it.
Easily washable, lightweight, and durable – that’s this Dynasty Store air intake system in short for you. It does an excellent job of maximizing the filtration efficiency and is available for a very reasonable price. It won’t be a perfect fit for Dakota’s engine, however.
3. Rtunes Racing Dodge Dakota Cold Air Intake Kit
If it’s ease of use/installation that you’re after, pay extra attention to what Rtunes Racing has in stores for you. The engineers did an excellent job of making this kit 100% compatible with the Dakota. Please keep in mind that it was designed to go with the older editions of this legendary Dodge truck – the 1997-1999 versions. So, only consider it if you’re driving one of the earlier models.
The package includes all the necessary hoses, reducers, nuts, and bolts. You won’t have to do order any extra parts for this air intake to work. The superb build and material quality are even more reason to consider it over the rivals. Some drivers report minor quality control issues, though. Keep that in mind and always check everything if you’re buying from a physical store.
This Rtunes Racing air kit is generously-packed, easy to install, and boasts above-average construction quality. In some ways, it’s quite simple and straightforward, but that’s more of a pro rather than a con. This product will serve you for many years and keep the engine’s temperature levels in control.
4. HPP Cold Air Intake Kit
This company was founded by two brothers and has been around for more than two decades. They know their craft and deliver only premium-grade aftermarket parts at an affordable price. The HPP cold air intake is made from the finest-quality materials – T-360 aluminum and (industrial-grade) stainless steel. Plus, the buyers will get one of the most detailed and helpful installation guides.
Personally, I was impressed by the customer service. The support agents are quick to respond and quite eager to lend that helping hand. The shipments do take a bit long to arrive, however, especially if you’re living in the suburbs.
HPP’s cold air intake system doesn’t have any significant cons except for the slow delivery. As for the pros, it’s crafted from top-notch materials and will be (relatively) easy to install. Dakota owners in the market for a capable air kit will probably find it to be worth the money.
Dakota drivers that want their engines to have an increased lifespan might want to consider investing in a good-quality air intake system. As I mentioned in the beginning, it’s not rare for the most powerful engines to overheat due to a lack of proper airflow. I spent a lot of time compiling this list; so, no matter which product you end up buying, it will most certainly be a reasonable purchase.
Some of the offers are more affordable, while others put quality first and will appeal to wealthier customers. K&N’s air intake kit isn’t particularly cheap, but it does have a couple of trumps up its sleeve. DNA has the most affordable option, while the other two systems are the closest thing to the golden middle. Take your pick, and share your experience in the comments!
