Have you recently bought a new Jeep Cherokee Cold Air Intake? Or are you just curious about the features or capabilities of this unique system for your car? But either way, today I’m going to answer your most important question, which is, can you actually drive your truck with a broken air intake? In fact, this is the most popular question among drivers, so you will be the first to know the answer today! Moreover, you will also be able to find out if there are any alternatives or it is totally restricted to drive without this system. So, if you are interested in this, then hurry up and start reading the article!
In order to understand if it is really possible to drive without a cold intake system, I suggest that you look into what this system does in general.
Firstly, the air intake system can certainly affect the speed and power of your car. The cold air intake system is the system that delivers cold air into the engine intake manifold. The standard air intake system more often than not has a lot of resistance to airflow. This is due to the paper filter and the manufacturer’s desire to decrease noise. More than that, the air intake is usually from the hot engine compartment. Furthermore, the air is hot, both through intake from the under-hood and by heating the plastic elements of the intake path close to the engine. All of this lowers the power of the motor.
Secondly, the speed of your car directly depends on the engine and its condition. That’s why it’s so important to keep your engine running as long as possible. Excessive heat causes a lot of damage to your vehicle’s engine. Since car engines are only made of metal parts, too much heat is very bad for your engine. Therefore, it is very important to have a good cold intake system and change it regularly.
Now we can conclude that driving without an air filter will cause dusty air to be sucked into the engine, and this dusty air will prohibit the formation of a thin film of oil between the moving parts, which is definitely bad news. The engine will be subject to a lot of wear and tear and will result in engine damage! This already threatens to damage the entire car! So, I strongly advise you not to do this to avoid further car damage.
That Is It!
In the end, now you know for sure that you can’t drive your car with a broken cold air intake system. What’s more, it’s dangerous due to it affects the performance of your car’s motor. I strongly advise you not to repeat such actions at home. I also hope very much that this article was very useful and informative for you. You can also write comments below and share the link to this article with your friends to keep up with all the news!
