Do you really want to mod a Jeep right now, but don’t know how? Then you have found the right article because today I will tell you how to upgrade your truck. The two best ways to do this are to set up or replace the old cold intake system and exhaust system. Jeep Cold Air Intake and exhaust are the greatest first mods to set up. However, you’re probably wondering which system you need to install first? Therefore, if you are interested, then read the whole article!
In fact, there are some reasons why you need to set up a cold intake system or an exhaust system first. So, in a nutshell, if you’re on a limited budget and your truck takes a long time to start up, then install the cold intake first. In contrast, if you’re on a bigger budget and you’re more worried about horsepower and aggressive sound, then try the exhaust intake first. But I’ll go into more detail about each option in a moment:
Here Are the Causes Why Cold Air Intake Has to Be Set First.
- Low cost
The cold air intake is not expensive as an exhaust. A great cold air intake costs about $300. Indeed, the price isn’t high, but even at those rates, you’ll find a quality cold air intake system.
- Good sound
The cold air intake is usually marketed as a way to increase engine power. Once the cold air intake is set up, you will hear the sound of air rushing into the combustion chamber every time you accelerate.
- Uncomplicated installation process
The cold air intake is much simpler to install and you don’t need to be a master, and it will take you 30 minutes.
- Unique design
Cold air intakes come in a bright color, such as red. When you set them up, your hood will look super cool. It will definitely be another plus to your truck’s design.
- Legal in all 50 states in the U.S.
Varying on the cold air intake, they may be certified legal in all 50 states. But make sure the one you buy has an Executive Order number on it.
Here Are the Reasons Why You Install Aftermarket Exhaust First.
- Great Sound
Aftermarket exhausts come with a less restrictive muffler. This means that the truck’s exhaust will sound louder.
- Performance gains
An aftermarket exhaust gives more power gains than another system. You can receive an extra 30 horsepower.
- Great design
When you set up an aftermarket exhaust, everyone will be aware. A great exhaust sound is one thing, and your vehicle will also look more aggressive because of the exhaust tip.
That Is It!
Bottom line is that if you are a beginner, I would advise you to install a cold intake system first because of the low cost and ease of installation, which is not unimportant. However, once you already have that system in place, then rush to install the exhaust. You’ll get even more horsepower and can make your car feel much more aggressive by tuning things like the Engine Torque Map. Also, I hope this article was helpful to you. If you liked it, you can share your thoughts in the comments too. Have a nice ride!
