If you own a BMW, you’re obviously lucky, as it is known to be one of the most powerful and upgraded vehicles. However, have you ever thought about modifications, such as installing an air intake system? Why this particular product? Because the BMW E36 Cold Air Intake can help you increase the power and performance of your truck as well as its efficiency. However, do you know how to choose the right one? If not, then don’t worry! Today I will tell you in detail how to do it!
What you really need to know is that absolutely all cold air intakes for BMW E36 are made to provide a significant increase in performance over the stock system that comes with your vehicle. However, it’s all up to you! Why? Because every driver has a different vehicle model and preference for upgrading. That is, your choice depends entirely on the options available for your BMW.
In order to make the right choice and not to make a mistake, you should follow these tips:
- Checking. Since manufacturers create a cold intake system according to vehicle makes, years of manufacture, and certain engine types, you need to pay attention to this. Before you buy, try to carefully check the compatibility of the cold intake system with your BMW. This step is very important because a lot depends on it.
- Material. The next essential step, in my opinion, is what it is generated of. As I already explained, the cold air intake should remove heat, so cooler air goes into the engine. Consequently, choose your system material carefully. Remember that it must be created of heat resistant materials.
- Type of the system. In fact, a lot depends on this item as well. There are two types of cold air intake: the short ram system and the truly cold air intake system.
Short ram system: If you choose this, you will simpler access to the air filter. Its style generally requires less “plumbing” or production work.
True cold air intake: This kind of system emphasizes moving the air filter far forward. It gives more additional cold airflow.
- Intake Tube. As far as I’m concerned, airflow depends on the hoses. Indeed, if you have a straight hose, it makes sense that the airflow will be faster. If they are curved, however, it will be slower. Hence, don’t skip this step when choosing a cold intake system.
That’s It!
Now you know all the basic steps for selecting a cold intake system for your BMW E36. It’s really not that complicated, is it? In the end, did you enjoy this tutorial? Also, I advise you to share your thoughts and experiences in the comments.
