The Ford Ranger is known to be one of the most powerful and top-of-the-line trucks in the entire world. And every driver surely wants only the most advanced equipment and modifications for it. And if you are one of those drivers, then I present to you the top of the best modifications for your Ford.
Floor Mats
When you buy vehicle floor mats, you get the best quality product that meets all the requirements of the consumer. The creators use rubber mixtures with high rubber content, which gives the mats high durability and wear resistance. Besides, they keep softness and elasticity irrespective of temperature changes, have no rubber smell, and emit no toxic substances. Moreover, the mats are practical and functional and have a modern design in the form of deep enough cells that perfectly retain dirt. They perfectly match the size of the vehicle floor, as well as securely fixed in designated places on the original mountings. In general, the floor mats have sides up to 15 mm high in the areas of the greatest accumulation of liquid, and in most cases, the driver’s mat has a special « foot», which covers the area (sitting area) under the left foot of the driver.
If we talk about the design of floor mats Ford Ranger, you can find a huge number of colors both on the market and in online stores. Cool, isn’t it? When you purchase front vehicle rubber floor mats, you will provide your Ford Ranger with protection from dirt and you will save money and time typically spent on cleaning.
You should also be aware that cabin mats are full size. This design feature of the mats increases the cleanliness of your truck. The driver’s mat goes far behind the pedals, and debris or dirt that might fall when your shoes and pedals come into contact will not fall on the vehicle floor, but on the mat. The rear mats don’t end with the line of the seat mounts but go deep under the front seats, which also increases the cleanliness of your Ford floor.
Tonneau Covers
I believe that the Tonneau cover for the cargo area of your Ford Ranger is the most important modification and improvement to your vehicle. No matter what the conditions, this product will definitely help you in many ways. All in all, the Tonneau Cover for a Ford Ranger has a huge number of advantages:
First, you can keep your tonneau safe and sound in this way. Moreover, it can prevent debris and dust from getting in there. Also, your tools and everything that lies there will be safe from theft. You won’t believe it, but this unit can even improve fuel economy by optimizing the aerodynamics of your Ford Ranger.
In fact, you can find a wide variety of colors and designs of these covers on the market or in online stores. All at your discretion!
Cold Air Intakes
The next modification that will help you improve your Ford Ranger is the cold air intake system. It is a cold air intake system for the engine intake manifold. It includes a zero-resistance filter and air intake duct.
This product is definitely a must-have for every vehicle as it has a huge number of benefits.
As you know, if cold air goes into the engine, then the power of your truck increases as well. This all happens because of the cold air intake system. Also, with this device, you have less possibility of getting detonation. Also, in summer or at high temperatures, your engine will run more efficiently. Great, isn’t it?
That’s It!
Now you are aware of all the modification options for your Ford Ranger. Here I’ve provided you with the most improved vehicle adjustments. In the end, did you enjoy this tutorial? Then I also recommend you to post comments and share this link with your friends.
