The Nissan Altima is one of the most upgraded trucks in the world. It seems that what else can be improved to increase the speed or power of the vehicle? Surely you have ever asked yourself this question as well as how to make my Nissan Altima faster? And I have the answer for you. Only a cold air intake system can help improve not only the power, but also the acceleration of your truck. Well, I will explain how important this system is for Nissan Altima in this tutorial. So, if you are wondering why this particular system you should install in your vehicle, then keep reading the following tips:
Firstly, air intake system can certainly affect your Nissan Altima’s speed and power.
A cold air intake system is a system for feeding cold air into the engine intake manifold. The standard intake system most often has a lot of resistance to air flow. This is due to the paper filter and the manufacturer’s desire to reduce noise. In addition, the air intake is usually made from the hot engine compartment. Moreover, the air is hot, both because of the intake from the underhood space, and because of the heating of the plastic elements of the intake tract, located close to the engine. All this reduces the power of the engine. However, if I’m talking about a modern and improved cold air intake system for Nissan, it’s incredibly useful for your vehicle.
Why? Because increased oxygen flow and lower air temperatures make for good combustion conditions, hence the engine starts to run. The main thing to remember is that the more combustion in the engine, the more horsepower the engine produces, and the faster your vehicle will go! Many retailers carry different styles and colors of cold air intake, such as AEM designs. With so many options on the market, you’re sure to find one that matches your vehicles aesthetic!
Secondly, the fastness of a Nissan Altima is directly dependent on the engine and its condition.
That’s why it’s so important to keep your engine running as long as possible. There are many factors that affect the life of your truck’s engine. In the first place, of course, is proper engine care. Excessive heat causes a lot of damage inside your vehicle’s engine. When the internal metal is hot, it expands, deforms, and even becomes brittle! Since auto engines are only made of metal components, too much heat is very bad for your engine.
Taking in cold air is a great way to increase the cold air flowing through your engine and allow it to run at a lower temperature than normal. Your radiator will also appreciate cooler engine temperatures.
That’s All!
So, you’ve figured out why you need to install a cold air intake system and why it’s so important for your truck. Besides, it’s not as complicated as it seemed. In the end, did you find this tutorial useful? Moreover, you can also post your comments below the article and share your thoughts and experiences.
