Nissan is a company that has been around since 1933. It has managed to make its mark in the automotive industry with innovative and reliable vehicles. The Nissan Titan was introduced in 2004 and it continues to be one of the most popular trucks on the market. If you own a Nissan Titan, then you are probably looking for ways to customize it even more than before, right? Well what about installing cold air intake for Nissan Titan?
You may be wondering what cold air intake is and why you should install it for your Nissan Titan. A cold air intake allows the engine to ingest cooler, denser air which results in more power. It also requires less fuel to maintain cruising speeds on the highway because of its increased airflow. Installing a cold air intake will help improve gas mileage by about 3-5% (depending on driving habits). If you are looking for an easy way to get better performance, look no further than installing a cold air intake!
As you can see, cold air intakes offer some advantages. They improve fuel consumption, make the engine more powerful and increase your gas mileage! If you want to get a jumpstart on those resolutions for 2019 or just want an easy way to save money at the pump, installing cold air intake is worth considering.
A Cold Air Intake Makes Your Engine More Powerful: A cold air intake allows the engine to ingest cooler denser air which results in increased power output by up to about 33%. This means that if you have a V-type configuration of two cylinders per cylinder head with four valves per cylinder then each engine will produce 132 hp instead of 71hp without any throttle input – quite an improvement! And since we all know how important it is to get the most power out of your engine while still conserving fuel, this could be a great option for you.
A Cold Air Intake Increases Your Gas Mileage: Installing cold air intake will improve gas mileage by about 30-50%. This means that at highway speeds there’s not as much pressure on the car and with less stress (fuel) being used in order to maintain cruising speed, more fuel can go towards acceleration which results in improved performance! And if you’re someone who does shorter trips around town or has congestion issues then installing a cold air intake would result in even better savings since those situations require lots of stop and starts – this also reduces wear…which translates into saving money.
One potential downside of installing a cold air intake on Nissan Titan is that it will not be compatible with an aftermarket performance exhaust system which can make sound levels and gas mileage worse due to less efficient engine operation.
It is worth considering this upgrade if you haven’t already installed one because it’s associated with many positive results including higher horsepower and more torque, improved fuel economy, cleaner air system (carbon monoxide levels will be reduced). There are some downsides to this installation such as incompatible aftermarket performance exhaust systems that can lead to worse gas mileage and sound quality.
