While we all know that regular engine oil changes are essential for keeping our vehicles running smoothly, many of us might not realize that mixing different types of engine oil isn’t necessarily a good idea. In this article, we will examine the possibility of mixing different engine oils.
What Types of Engine Oils Are There?
The most common types of engine oils are synthetic, conventional, and high mileage. Synthetic engine oils are designed to provide superior performance and protection in all types of weather and driving conditions. They are also more expensive than conventional or high mileage oils. Conventional engine oils are a good choice for most drivers and vehicles. They provide adequate protection and performance in most conditions. High mileage engine oils are designed for vehicles with over 75,000 miles on the odometer. They help to prevent leaks and oil consumption in these older vehicles.
Can You Mix Different Engine Oils?
Different engine oils can be mixed together, but it’s not recommended unless you are topping off your oil level and don’t have the same type of oil on hand. In general, it’s best to use the same brand and type of oil in your engine to ensure optimal performance.
Is it worth Mixing Different Engine Oils
In fact, mixing different types of oil can actually do more harm than good. It all has to do with compatibility. Different oils have different additives and base oils that can react with each other in undesirable ways. For example, some oils may not mix well and could separate, leading to decreased performance and protection. Additionally, mixing different oils can throw off the correct oil level in your engine, which could cause serious damage.
Drawbacks of Mixing Different Engine Oils
Although mixing different engine oils may not have any immediate effects, it can cause long-term damage to your engine. Over time, the different oils will break down at different rates and form deposits and sludge. This can clog up your engine and reduce its efficiency. In worst cases, it can even cause your engine to seize up. So while you may be able to get away with mixing different engine oils in the short term, it’s not worth the risk in the long run.
Different engine oils have different properties, and these properties can interact in unexpected ways when they are mixed together. For this reason, it is not recommended to mix different engine oils together. If you do need to mix different engine oils together, be sure to add the new oil slowly and carefully, while monitoring the engine closely for any adverse effects. It is also a good idea to consult with a qualified mechanic or technician before mixing any oils.
